10-13-2016
01:14 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
10-13-2016
01:14 PM
Hi Pendean.
You`re right. if you check the properties says: Annotative: No, but when I do menu "Dimension" > "Update" and select all...that property turn to Yes, and shows the scale set, and everything goes normal.
I`ve changed the properties manually, save, close, open...and...the problem is the same,
