Alfred.NESWADBA
en respuesta a: Anonymous
welcome @Anonymous.autodesk.com!
Does that happen in new files too? If "new" based on your template also has that issue then try a new file based on an AutoCAD original template.
When you run command _RECOVER instead of _OPEN to open your file, do you get errors in the drawing displayed (and repaired)?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
