- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi people.
I´m having an awkward issue with annotative texts and dimensions in Autocad 2010.
I.E.: I configure an annotative text style, then I use that text to set an annotative dimension style. I made my drawing, I set Vports in papersace, set scales and everythings goes normal. I finish, close the file and go home after work. But the next day, I open the drawing for an editing session and...the texts and dimensions display big, very big, unscaled. (It is not a scale problem, I use a template made by me for years and never happened).
So...I use "dim" > "update"...select everything...enter... and seems to be the solution. But it is not a definitive solution because every time I open the file the texts and dimensions apear unscaled.
Now is getting worst, when update the dimensions some of them change style (jump from style to another). I mean: the style in use is "Ann 2.5mm" and updating the dimensions change to "Standard" or another one.
It only happen when opening the drawing, once you update, the editing session goes normally.
Any idea?
I´ve tried changing "msltscale" parameter (just in case it was a display issue)...I create a new template, with new texts and dimensions and still happening so it is not a file issue, its an Autocad issue (and I don´t remember exactly when it started).
Thanks for helping...or at least spend time reading it.
¡Resuelto! Ir a solución.
