274 Vistas, 1 Respuesta
Have Text from Dimensions be larger by default
Currently, as I used the dimension tool to help display line measurements, I need to zoom really far into the line in order for the text to be visible. Instead of manually changing the text size in properties, how can I default the text size to be large. Or, is there a command that I can do once all of them are finished to increase them all at the same time?
