11-22-2016
06:38 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
11-22-2016
06:38 AM
>> I checked the object type and it is a raster image, the layer is able to plot, and the
>> viewport is set to 2d wireframe. I also tried changing the resolution down as low
>> as possible and the image still wont show up in the PDF.
Can you try the same in a new drawing?
Do you have another PDF-printer installed in your system (like PDFCreator) and can you try to plot to that device? Same result?
If nothing helps: can you use _ETRANSMIT to create a ZIP from the drawing and the image and upload the content so we can see what you have?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Alfred NESWADBA
