Alfred.NESWADBA
en respuesta a: Anonymous
welcome @Anonymous.autodesk.com!
Is your raster image inserted with the command _IMAGE or is it an OLE-object? (select it and look to the property window, what it reports as objects type).
Or ... don't you speak about an image when you say:
>> I have a PDF of an image and then vectors on top of it
At least the same... select it and let us know which object type it is exactly.
Most common to plot issues with raster files or with some objects not appearing in plot result are:
  • the layer of the object is set to no-plot
  • the viewports are set to rendered styles or hidden or something like that, make sure they are set to "2D-Wireframe"
  • reduce the resolution of the PDF-plot device for raster content, down to 100 or 200dpi for test, if that helps you can raise the value up to failures
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
