pendean
en respuesta a: Anonymous
I'm going to guess you are making this mistake:
- You change the settings in the DWT file.
- You reopen the DWT file and it's no changed.
- You skip the part where the DWT file needs to be a DWG file, you make and save changes to it first, then replace the old DWT file with the altered DWG file (and rename the extension DWT).
OR... you are still accessing the old DWT file when you use the default 'template' option in AUtoCAD which is disregarding any new templates you created.
Which is it? Attached is your file, I changed the DWT to DWG, made the changes, saved the file, changed it back to DWT. Opened it several times last night and this morning and miraculously it's still the same way I set it and NOT the way you had it.
