- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I use INSERT command but until i don't select an insertion point i don't dynamically see the block, so i don't know how to orient it
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Karol-Or,
The normal INSERT command will not show a preview in the dialog such as Design Center does.
However, it should show you a preview when asking for an insertion point. Is it not doing this for you?
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Do you have DRAGMODE turned off [the System Variable set to 0]? Set it to Auto [System Variable 2].
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
There is no preview during insertion even with DRAGMODE on.
Now i see that if i uncheck the Explode option in the INSERT dialog it is shown. this is on Acad 2006, i didn't check it yet on 2013
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
that is true.. when Explode is ticked you will insert non block items,for this you will not see any block preview.
Imad Habash
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Imad Habash
