1201 Vistas, 6 Respuestas
Non-Standard Dimension Text Leaders
When a dimension is too large, it pops out on a leader that is angled (yellow), but I want them to always pop out at 90 degrees (blue) without having to manually move them all.
I am not talking about resizing the dimension...this is for after I have selected a size, but the smaller dimension's text does not fit "in-line"
john.vellek
en respuesta a: Anonymous
HI @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
Can you attach a sample file with your leader style?I don't know if I have a solution but I would like to give it a try for you.
John Vellek
As far as I can tell they are both the same but one is placed manually.  Try this in the Style manager
This may Help.
en respuesta a: john.vellek
Sure.  Here is a sample.
pendean
You can't fight the problem: it is designed to pop the leader from the dimline at an angle. You will need to customize with overrides if you want a perfectly vertical line-leader as far as I can tell.
If you go into Dimension Style -> Under the Text Tab -> Text Alignment Change it to Horizontal that fixes it.
This is what I did to your drawing they all came out at 90.
YES!!  It has one downfall, which is that the vertical dimensions will now have horizontal texts, but that is WAY easier to deal with than the angled leaders!!
Thanks you so much!
