948 Vistas, 4 Respuestas
Redirect folder My Document in AutoCAD 2016 very slow in opening
Hi all,
When I tried opening files from the folder that was redirected from My Documents, opening it takes a lot time. Is there any workaround with this? Please help.
Thank you.
Harv.
imadHabash
en respuesta a: Anonymous
>> opening it takes a lot time <<
  • does this happened in every CAD file or in a certain one?
  • what is the size for this file?
  • does this problem appeared lately?
  • we need to know and see the CAD file (if it's possible) to test it in our PC.
  • is there a lot of xrefs attached or what?
would you answer these above questions to start finding proper solution for your case.
Note:
maybe you can start use AUDIT and PURGE(Regapp) commands and see if there is any differences after that.
Imad Habash
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
How is this folder being redirected? Is it part of a roaming profile? Is this on a network location such as a NAS drive?
I wonder if you are having some latency due to permissions or network conditions.
John Vellek
john.vellek
Hi @Anonymous,
I am checking back to see if you have had the chance to explore any of the suggestions in this thread. Please add a post with your status.
John Vellek
en respuesta a: john.vellek
Already fixed up, i just cleaned up my drawings and the xRef also, removed the unnecessary elements.
