02-01-2017
09:55 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
02-01-2017
09:55 PM
>> I've already specified the line weight
In the video I can't see if you have activeted LWDISPLAY (to present line-weights on screen)
>> I change the line thickness
Line-thickness is a setting for 3D ... so the object gets something like a height. You can't see that as long as you look to the drawing from top.
The issue at the beginning of your video when you need to change the layers color to see the change to the lineweight looks like a graphic card issue.
Am I correct that your graphic card is an Intel HD....?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Alfred NESWADBA
