john.vellek
en respuesta a: Anonymous
Hi @Anonymous,
As @Alfred.NESWADBA suggests, create a new drawing based upon your template file. Save/close the file and then reopen it. DO you see the same message in this file now/ If os, it means that you have a problem with your template file.
You can run EXPORTTOAUTOCAD on your template file to create a new file which you can then use to replace your current template.
This command will also "fix" this message on existing files that open with this message.
John Vellek
