Alfred.NESWADBA
en respuesta a: Anonymous
>> All files are created in AutoCad or AutoCAD based tools
Create a new drawing based on an original AutoCAD template, draw one line, save/close/reopen the drawing ... same message?
If yes, then please let us know what "AutoCAD based tools" are, they might influence the saving of objects, so with a very little chance that could be a reason.
If you then don't get that message I guess the drawings were not saved by yourself, so any other software had the drawings opened and saved.
>> Will copying date from external files results in this?
Also only wit a very little chance, because when you have plain AutoCAD and run a _SAVEAS command, so saving the file with your AutoCAD, the message should not appear with that file.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
