Moshe-A
676 Vistas, 2 Respuestas
Authorization Error Login failed. Error -551
Hi Guys,
Have a machine (win7/64 pro) joined to domain (sbs2011) installed with AutoCAD 2015 + AutoCAD 2016
early this week i gave this machine to other user, disconnect it from the domain and rejoined it with the
the other user profile
since then the user complains: he opens his dwg files getting Authorization error (see the pic)
i would like to mention that before, this machine was working prefectly
when disconnecting to machne from the domain, the error is vanish
workaround?
thanks in advace
Moshe
john.vellek
en respuesta a: Moshe-A
Hi @Moshe-A,
If removing the computer from the Domain fixes the problem, then there is likely an issue with the domain user profile licensing.
I suggest clearing the license date using the following steps;
  1. On your computer logged on as the Domain User with full local Admin permissions), navigate to: C:\ProgramData\Autodesk\CLM\LGS\<product key>_<<product version>>\
  2. Delete the LGS.data file.
  3. Navigate to C:\Users\<username>\AppData\Roaming\Autodesk\
  4. Delete the ADUT folder and it's contents
  5. Start the application.
John Vellek
john.vellek
Hi @Moshe-A,
I am checking back to see if my post helped you with your problem or if you need additional assistance or information. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
