john.vellek
en respuesta a: Anonymous
Hi @Anonymous,
Yes, very strange! What happens if you work with Hardware Acceleration turned off for a little while. It would be interesting to see if that has any affect.
I don't see anything unusual in your drawing that would cause such behavior. I was able to remove 19 Regapps though using -Purge>Regapps.
Other posts indicate that if the objects are moved away from grips that exploding and then performing an Undo will return them to the proper spot. I don't see anything like that here.
I will keep looking.
John Vellek
