- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
>> I think you can elaborate technical drawings even on Photoshop
>> the result is what's most important.
Correct, but not the paper is the result! Try to forward data into a manufacturing process like use the data on CNC systems or 3D-printer or create calculations based on architectural details like room-area, wall-area or listing number and sizes doors, windows, of electrical sockets or number of screws in a BOM for cost calculation or .... there exist thousands of samples.
SCNR:
Sorry to say, for me that sounds like your "result" is just the paper. In that case you loose a lot of money because you don't use all features you have within your CAD-system. You will never be able to create an associative dimension or a symbol with attributes that can be counted afterwards ... and that are the default functions used by all (trained) CAD users.
If you do only draw lines, then it's like @pendean wrote: "It's your choice" ... and I would add, it's like having a Ford Mustang, but only drive with 10mph.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
