- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Mouse jumping around 1 autocad file
Dear all I'm confronting problem with one of my auto cad file mouse keep jumping around only with one file.
when I set my settings of the Auto Snap (system Variable) to 32 the mouse work perfectly but the marker doesn't show.
when I changed the setting (system Variable) to any other nr like 0,1,2,4,8,63 the mouse keep jumping around.
I've perform some test.
when I set the AutoSnap (system Variable) to 32 and manually enable the marker in the option of "snap and grid" mouse starting jumping around again. ( it seems when the marker has been enabled the mouse start jumping around)
Set the file locally on the PC and also via network share the file is 23 MB keep doing the same
I also rename the bak file to dwg the mouse still keep jumping around.
Also perform Recoverall Commando but no error where found in the file.
Hardware acceleration has been disabled still jumping
The file has been tested with auto cad 2016 and 2017 also run sp1 mouse still jumping around.
Tested on windows 10 and Windows 8.1
Can someone please help me with this problem?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
It looks like you are looking for information related to recovery from .bak to .dwg. Community members with similar questions found the following article(s) useful:
How to show or hide file name extensions in Windows Explorer
If this information was helpful, please consider marking it as an Accepted Solution by clicking on the "Accept as Solution" link, below. Taking a moment to do this will help others with similar questions find useful answers. Thank you!
Kudos (click on the link or the "thumbs-up!" icon), are also gratefully received! (Even a bot likes praise.)
If this answer missed the mark, please let us know so that other community members can lend a hand. Any additional details might help, too: consider including relevant screenshots, log files, error messages, or system specs.
I'm a software-based HelpBot, designed to provide the information you need to get up and running with Autodesk products—any time, day or night. Your feedback will help train me to deliver more accurate and helpful answers. Thanks in advance! Also, please note that I'm only set up to respond to the first post of a topic, not to any replies. Thank you!
Helpful links: Find Serial Numbers and Product Keys | Find Downloads and Service Packs | Activate Autodesk software
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
what happens if you create a new file and use copy & paste to copy the geometry from the existing file into the new one, does the new file have the same issues?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
Please ignore Otto - he is on a learning curve ![]()
If this is only happening in one file, I suggest that you try an Audit, Purge, -Purge>Regapps and even an ExporttoAutoCAD. @Alfred.NESWADBA's suggsetion is also great to try.
Please attach the file to a post if you would like me to investigate.
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
It sounds like grid snap is on.
Rob
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem.
Please add a post with how you decide to proceed and your results so other Community members may benefit.
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi John,
sorry for the delay today I'm going to perform all those test and I will feed back.
