01-18-2017
05:21 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
01-18-2017
05:21 AM
Hello seucanlaurentiu,
If you're looking for command overwriting, i suggest the command aliases that you can find in acad.pgp file.
To find it, follow the instructions in this link:
Once you open the file, go to the bottom, and there is a place, where you can set "User Defined Command Aliases", that will overwrite any default commands that are assigned to letter "D". You can edit the default command shorctuts as well, but those changes won't be migrated if you upgrade Your AutoCAD version.
Kind Regards,
Pawel
