marius_n_costea
1521 Vistas, 5 Respuestas
Locking Z values to existing elevations.
Hello.
I am trying to keep the z elevations how they are.
In other words I am using 3d features regarding elevations but I also need to use o-snap features.
I am looking for a command or a way to lock the elevations, so I would be able to move the desired level point / objects / whatever even if it snaps to an object, I desire to have the same initial elevations.
Usually when you move elevations and the snap to an object they either add the value of the snapped object or move it to the same level.
I hope I have been explicit and clear enough...
Thank you in advance for any attempts of help!
imadHabash
en respuesta a: marius_n_costea
Hi and Welcome to AutoDesk Forum,
if i understand your need.see attached image and see if it could help from OPTIONS command.
Imad Habash
rkmcswain
Explore the system variable OSNAPZ. It should help you do what you want.
marius_n_costea
en respuesta a: rkmcswain
Thank you!
It did exactly what I needed!
Have a nice day!
marius_n_costea
en respuesta a: imadHabash
Thank you!
This one does the trick as well!
Take care!
Kent1Cooper
Another approach is with point-coordinate filters.  When it's asking for a new location, type .XY [with the preceding period/decimal], Osnap to whatever, and it will ask for a Z value -- Osnap to the point you're altering at its original location to have it use its original Z coordinate.
Kent Cooper, AIA
