3709 Vistas, 3 Respuestas
DXF with specific origin
We use Acad17. Is it possible to create DXF file, using DXFOUT, with the select objects option and have the DXF created with the bottom left point at 0,0. We have a new Cam package and it's proving to be a hassle to edit each DXF and move the objects to 0,0. Our old program imported the DXF and automatically centered it on the created panel.
TheCADnoob
en respuesta a: Anonymous
Have you tried just saving the dwg using save as?
CADnoob
process_solutions
en respuesta a: TheCADnoob
(Defun C:SET_DXF_ORIGIN ()
(setvar "treedepth" (getvar "treedepth"))
(COMMAND "ZOOM" "EXTENTS" "REGEN")
(setvar "INSBASE" (Getvar "Extmin"))
(princ)
Run the above to set the insertion base of the dwg to the lowest left point, or literally type
INSBASE
0,0,0
IF 0,0 is exactly where the origin should be, but if the data is not already located with the extmin at 0,0 it may be necessary to move the data to 0,0... I use the following regularly:
(defun c:Relocate_to_Origin ( / osmodewas)
(setq osmodewas (getvar "OSMODE"))
(setvar "osmode" 0)
(setvar "VTENABLE" 7)
(command "zoom" "extents" "REGEN")
(command "-layer" "unlock" "*" "" "move" "all" "" (getvar "extmin") "0,0")
(command "zoom" "extents")
(setvar "osmode" osmodewas)
(setvar "VTENABLE" 3)
(princ)
Hope these ideas help.
Sean
en respuesta a: process_solutions
Thanks guys
  Using saveas won't work, I just need specific parts of the drawing DXF'd
I tried the code as well, seems to work great. I was just hoping there was a parameter some where that would do it without adding extra steps. As you all know, if I need 20 DXF's out of 1 drawing every step counts.
Thanks again
Really appreciate the quick responses.
