01-11-2017
03:37 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
01-11-2017
03:37 PM
FWIW - When I switched from 2014 to 2016 what you
are describing [ID_helpstrings] went away and I too was
not able to find a way to display this extended help.
Blame it on the upgraded UI with the jumpy tab bar.
There is a line inside the CUI --> Properties pane that is called
"Extended Help File" that you can use however at this time
this feature is not developed enough to be able for us
developers/end users to migrate our work to other workstations
easily. To see it in action, hover your mouse over a toolbar
button / ribbon button, pause, and the tooltip will expand.
Tooltips do not appear when hovering inside the Menubar.
Here's a thought - How does one hover over a control in order
to display it's tooltip on a touchscreen device?
I do not own any touchscreen devices, therefore I do not know
this answer.
this answer.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.![]()
