Alfred.NESWADBA
en respuesta a: hortonsam2k
>> As of now it says...  pdf failed
Wow, what is "it", what tells you pdf failed and what have you done to get that message?
The content of the sysvar PDFIMPORTFILTER is described >>>in the help<<<, which questions are open for that?
If you use the command _PDFIMPORT you get a dialog with checkboxes to assign what to import and what not ... does that answer your question?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
