- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hey everybody,
I've already made a post about this, but happened again with 4 different computers, so I'm pretty sure it's a bug. However, someone from the forum was able to do it for me the other time.
I only need someone to do this simple command for me so I can finish this project for tomorrow. It would help me a lot!
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
As you described, SLICE pick the Yellow surface, enter, S for Surface, pick the gray and Enter, then Move the Yellow surface to see what it's done.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
But I worked for you. What is in the picture is exactly what I'm looking for.
Could you do the same thing for the other side and send the file? It would help me a lot!
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
The other end didn't work, it doesn't intersect, you need to redo the slicing surface.
I moved it a little and it sliced but I don't know how accurate you need it so I leave it un-sliced.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Actually I only need the front part, I can copy that little piece for the back side.
Could you send the file, please?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I can't access to it, it's on another worker's PC.
If you attach the same dwg in 2007 version, maybe I can do it.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
the resulting drawing has > 200MB, so it's ZIPped and you have to unzip it before loading into AutoCAD.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
