- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
From Autodesk help
F2 Text Window disappears
2016-04-21
Issue:
You want to see the history of your commands via the Text Window. However, when clicking F2, the text window showed up briefly but disappeared.
Causes:
The text window is probably hidden to the back of AutoCAD.
Solution:
Enter TEXTSCR in the command line or Ctrl+F2 and see if it brings up the text window.
If it comes up, move the application window to the other screen (if you have none then move it a little bit to the left or to the right) and you'll see the text window
The other way alternative is to get it from the taskbar for your AutoCAD session (one for the main application, one for the text window) ==> selecting the text window icon pushes it to the front.
Putting the window on the second monitor work fine for me.
dave
