01-05-2017
07:07 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
01-05-2017
07:07 AM
- Try to determine if the error is file based or program based. I realize that can be difficult if you're on the clock. But you may have a corrupt file (or files) that is causing it. Don't forget about checking your Xrefs and if this is Civil 3D, data shortcut reference files also.
- Make sure you have ALL of the service packs and applicable Hotfixes and other patches installed.
- Make sure you are running a supported video card and that you are running a supported driver for it (which may NOT be the "latest" vendor driver).
- Empty (and keep clean) your %TEMP% folder.
