en respuesta a: Patchy
GRIPOBJLIMIT is set to 100 which is the default and the max I believe. I've attached the drawing file and a screenshot below to show you what to look for in the file.  If you look at the face of the shed with the door opening, you will see that the pink insulation panels don't all have grips. Some do, and some don't. I don't know what the difference is or how to turn them on for those objects.
