en respuesta a: imadHabash
Thanks for your timely response. This issue is not the grip settings. I have tried GRIPS 1 and 2. I have also confirmed that the grips size settings are adequate. If I draw a new rectangle, the grips are present. For some reason,  some objects have the grips and some don't. I have attached an image where you can see one panel has grips but the panel beside it does not have grips.
