01-04-2017
02:56 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
01-04-2017
02:56 AM
>> Have I accidentally turned off the grips somehow? <<
GRIPS system variable Controls the display of grips on selected objects
0 |
Hides grips |
1 |
Displays grips |
2 |
Displays additional midpoint grips on polyline segments
To adjust the size of the grips and the effective selection area used by the cursor when you snap to a grip, use GRIPSIZE.
type GRIPS in command line and try this values as you need.also you can try from OPTIONS command Grips options.(see attached image)
Good Luck..
Imad Habash
