- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I have insulation on a building which are rectangular prisms, and I need to put them in different walls. The insulation needs to be resized according to the boundaries of each section. For some reason, when I select the insulation it does not show the blue dots or stretch vertices on the face I am viewing. I would like to be able to click the vertex on an edge for example, and stretch or shrink that to the right size. If I draw a new rectangle somewhere, it seems to show the vertices for that new rectangle, but none of the existing objects. Have I accidentally turned off the grips somehow? I've attached an image where you can see in "the way I want it" there are blue dots in the center, corners, and edges at the midpoints. These blue dots are the grips or stretch vertices I am referring to.
Thanks in advance!
¡Resuelto! Ir a solución.
