- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
NEED HELP IN DIMENSION PROBLEMS IN CAD BLOCK AND CAD MODEL PAGE
PLease help Me…I need Help (AUTOCAD 2013)
I Have cad block Desk in 180*180..
But after editing from Block editor In my Autocad Model page its showing 162*162
WHY ITS HAPPENING…!!
Block editor 180*180 after that in Cad Model Page 162*162 Why ?
Please check the LINK FOR IMAGE
Download link
https://we.tl/QkCbfQfZHW
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
welcome @Anonymous.autodesk.com!
I can only guess: the block that is inserted, was scaled? Select it, open the property window and look to the ScaleX and ScaleY settings.
If you upload a DWG we don't need to guess ![]()
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
Can you attach the original block to a post? I would like to see if I can duplicate this and find an answer for you.
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thank You very much for Your Comments..
Still now i'm in Trouble Please help me to find Solution.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
I took a look at your block and discovered if I increased the accuracy in UNITS, that when I modified the geometry in Block Editor and then saved the block it works fine.
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thank you For your Solution.But its not working in My computer.
I tried but its still same like that
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
With your units set to a higher accuracy, you will need to adjust your block or redraw it as the original is not drawn accurately to the dimensions you show. I had to do that with the block I attached earlier.
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
It is a block inserted with wrong scale as Alfred said.
Copy it several times, scale it and explode, now look at the dimensions.
