- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
If you use (or wish to upgrade to) AutoCAD2017, go grab the 2017.1.1 update (notice the "point one point one" in the name) from your active subscription-only updates page https://manage.autodesk.com/cep/#products-services/updates
Read all about it here: http://blogs.autodesk.com/autocad/autocad-2017-fall-update/
Note: It doesn't solve all the problems, just many of them. A better fix will probably show up in AutoCAD/LT2018 next year of AutoAd/LT2019 the year after that.
But... AutoCAD 2016 and lower versions were not designed for high-res monitors AND AUTODESK HAS NO PLANS TO EVER CHANGE THAT REALITY. These older versions will only run on displays set to 1920x1080 (also try 2560x1440 and up to 2560x1600 if you have that option) and at 100% text scaling (no more than 125% text scaling).
Read all about it here http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Odd-gra...
