572 Vistas, 4 Respuestas
How to connect different type of lines
Hello guys i have a problem.
I have  3d object (comlicated power-transmission pole) in AutoCad drawn only with lines and now i'm tryin to connect these lines in 1 object. Is it possible ? Command "Join" don't work because i have different type of lines . Can some one help me ?
This is how it looks like
en respuesta a: Anonymous
Make it a block with the BLOCK command.
or
Make it a GROUP
imadHabash
Hi and Welcome to AutoDesk Forum,
>>  i'm tryin to connect these lines in 1 object <<
you can also Attache it as Xref reference from XREF command.
Imad Habash
en respuesta a: imadHabash
Thank you guys !! And is here any way to create body from this lines ?
imadHabash
usually 3D models consist from Solids and/or Surfaces elements. from these you can create elevations and sections and manage it as your need.since your 3D consist from lines you will loose all 3D models AutoCAD privileges.
Imad Habash
