- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
@jcavanagh wrote:Our office is migrating our dimensions, text and certain blocks to be annotative. We're finally jumping into the 21st century :-). I'm currently in the learning process of how Autocad 2017 deals with annotative items, so please forgive me. I mostly understand and have had zero issues converting our text styles, dimensions styles, templates and etc., the one and so far only issue that I'm having is this:
I draw a detail in model space, I set the annotation scale to 1" = 1'-0". I open our sheets file that has our title block xrefed onto a layout tab, S1.0 ( paperspace). I xref in the detail onto sheet S1.0, which is in paperspace and the plot scale is set to 1:1, I choose the location of the detail and I scale the detail down to 1/12. I do that so the detail is now 1:1. This is where I'm having the issue. Sometimes I need to change the scale of a detail from 1"=1'-0" to 3/4" = 1'-0". I open the detail xref, I select all of the mleaders, select "Add/Delete Scales" on the ribbon and add 3/4" = 1'-0" to the object scale list. I then change the annotative scale of the drawing from 1"=1'-0" to 3/4"=1'-0". So the scale of my detail is now 3/4" = 1'-0". I save my drawing, I then go into my sheets file and reload my detail xref. I then scale my detail down 3/4 so that the detail is now at 3/4"=1'-0". The scale of my annotative objects (text, dimensions and blocks) stay at 1" =1'-0" and don't change to 3/4" = 1'-0". Why doesn't the annotative objects in my xref change to 3/4" = 1'-0"? I've tried to detach the detail xref, purge the sheets drawing and re-xref the detail back in my drawing in paperspace and the text/dimensions are still showing at 1"=1'-0".
I've attached the dwg's that I'm working with to this thread, so please review.
You're scaling what you've previously drawn (lines, arcs, circles and such) and putting them in paper space?
