marco.defina
3018 Vistas, 8 Respuestas
PCP exported from Revit fails in AutoCAD
i exported .dwg from Revit...So io try ti print with AutoCad, i try to create the .ctb from the .pcp exported and i receive this error...
@marco.defina; john.vellek has edited your subject line for clarity:PCP exported from Reivt
BIM Manager - HVAC and Plumbing designer https://www.autodesk.it/content/dam/autodesk/www/products/responsive-imagery/responsive-badges-compare/2019/navisworks-manage-2019-badge-75x75.pngApp AutoCAD per dispositivi mobili premiumNavisWorks Simulate3ds Max___________________________________________________________________________
Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums.
john.vellek
en respuesta a: marco.defina
Hi @marco.defina,
Can you attach some files to a post? i would like to see if the conversion fails on my side as well.
Please also give me the version numbers of both Revit and the AutoCAD you are using.
John Vellek
marco.defina
en respuesta a: john.vellek
Hello @john.vellek,
i have Revit 2017.1 and AutoCad 2017...
Attached the .pcp file...
john.vellek
Hi @marco.defina,
I didn't have any issues with importing the PCP. I imported it by Options?Plot and Publish>Add or Configure Plotters which started the Add-a-Plotter Wizard.
I attached my resulting PC3 file for you.
Perhaps the issue is actually in the drawing. You are welcome to attach it here or send to me personally at john.vellek@autodesk.com.
John Vellek
marco.defina
but i tried to create a ctb from pcp, not a pc3...
Alfred.NESWADBA
PCP and PC3 are plotter device configurations. (PCP can be converted to PC3 as both are plotter device configs)
CTB is a color conversion config.
You can't convert a plotter config to a color conversion table.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
john.vellek
Hi @marco.defina,
I am checking back to see if my post or @Alfred.NESWADBA's helped you with your problem.
Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please select the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
marco.defina
So the problem is that i did not understand the i cannot create a ctb from a pcp but only the pc3...
The window where you can create a ctb from pcp or pcp2 confused me...
Thanks...
italonge
Hi everyone
I have a problem with .pcp too...
I need to create a .ctb file, and what I saw is: .pcp is different from .ctb, ok... But what could I do to export a DWG file and plot a PDF with same colors and lineweight from Revit's PDF?
.pcp can do that?
Or there is an other way to get this result ?
Thank you!
