12-19-2016
05:32 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
12-19-2016
05:32 AM
i try a lot to open the file but it seems that it's corrupted for some reason... i suggest to do the follow:
Look in the same directory where the DWG resides and see if there is a BAK file of the same name. If so, rename the BAK extension to DWG and see if the file can then be opened.
Look in C:\Windows\Temp for files with an SV$ extension. If any exist with a similar name to the corrupted DWG file, then rename the extension to DWG and see if it can then be opened.
hope that help.. Good Luck..
Imad Habash
