lautarolzl
505 Vistas, 5 Respuestas
Problem with vertex's axis
Hello everyone! I'm having an issue with the vertex's axis, it's different from my working space axis, it should be orthogonal! How do i unify them?  Thank you!
Etiquetas (2)
Patchy
en respuesta a: lautarolzl
Try SNAPANG and use zero.
lautarolzl
en respuesta a: Patchy
Thank you for your reply, unfortunately, it was already set to 0, any other
idea? :cara_de_decepción:
john.vellek
Hi @lautarolzl,
It is a bit tricky to see what your issue is here but if Patchy's guess is correct then I suggest also to use SNAPANG but instead of entering 0, try selecting the end points of one of your horizontal lines.
Please feel free to attach your drawing here also If you want me to take a look.
John Vellek
john.vellek
Hi @lautarolzl,
I am checking back to see if my post or others helped you with your problem.
Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please select the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
lautarolzl
en respuesta a: john.vellek
Hi John!
I tried the SNAPANG command again and did the trick. I don't know why it didn't worked before, a bug maybe.
Thank you for your help! Robot feliz
