12-12-2016
07:35 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
12-12-2016
07:35 AM
Hi @Anonymous,
That is a very tight radius for such a door section. I would approach drawing it the same way I would construct it. First, analyze what parts are cruved or not. For instance, the stiles are not likely going to be curved. So, I would place them at then ends of the curve to see what elements will need to be curved.
Next, I would sweep a closed profile along the radius for the bottom rail. Similarly you can do the top but it might take quite a bit of work to sweep the several profiles necessary for the pattern.
Again, I question how this would be built for real and would follow the same approach in your drawing.
John Vellek
