322 Vistas, 5 Respuestas
plotting clarity
I just purchased AutoCAD 2017. I can't get my drawings to plot with the color in which they are drawn. Hatching colors are off as well as text color. The entire drawing comes out fuzzy as well. I tried to turn it into a PDF but it still does the same thing.
pendean
en respuesta a: Anonymous
Post your DWG file here, we all have R2017.
en respuesta a: pendean
Amy Shenkenberg
john.vellek
Hi Amy,
I am sorry you are struggling with getting your colors to plot correctly.  I found this article on Plot Style settings and thought it might be a good starting point for you.
Here is a look at my out-of-the-box acad.ctb file. you will note that by default it should allow you to plot the color of the object.
Please let me know how you are using plot styles and how you are plotting. I would like to see your drawing file also. If your attachment didnt stick then you can email to me at john.vellek@autodesk.com and I will put it on your post for you.
John Vellek
pendean
You can't post a file with an email reply: you have to come to the website, use the REPLY button, and attach your file.
john.vellek
Hi @Anonymous,
I am checking back to see if my post helped you with your problem or if you need additional assistance or information. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
