Kent1Cooper
en respuesta a: Alfred.NESWADBA
@Alfred.NESWADBA wrote:
If you don't have AutoCAD 2016 or newer you have to ... modify all objects and set the properties to "byLayer".
... if they're all on the same Layer [preferably Layer 0, if you want them to take on the color of the Layer the drawing is Xref'd into], or at least all on Layers of the same color.  If the Xref'd drawing contains multiple Layers with different colors, and the objects are ByLayer in color, they'll still be different colors in the drawing it's Xref'd into [unless you can override that in the newest versions as described].
Depending on what the drawing represents and how it will be used [obviously this will not always be viable for purposes of the drawing on its own], consider making all the objects in it ByBlock in color.  Then you can give it, when Xref'd in, a color either by the color of the Layer you Xref it into, or with a color override, and all parts of it will be the same color.
Kent Cooper, AIA
