Alfred.NESWADBA
en respuesta a: Anonymous
the problem arises when the referenced drawing(s) contain ibjects, that were not created with color = byLayer.
If you do have AutoCAD 2016 or newer you can activate XREFOVERRIDE (>>>details<<<) which means the main drawing uses the referenced content in the same way as the geometry would have been created with color = byLayer (independent of the real setting of the elements).
If you don't have AutoCAD 2016 or newer you have to open the drawings you use as XRef and run command SETBYLAYER (>>>details<<<), this will modify all objects and set the properties to "byLayer".
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
