689 Vistas, 4 Respuestas
Windows 10 Compatibility
Hello Sir/Madam,
I work for a company called 848 group. We are currently running an application intelligence project before we get ready to swap out Manchester Airport PC's from Windows 7 to Windows 10. A number of these users are running some software you supply called:
AutoCAD LT 2008 - English                    17.1.51.0
Autodesk 3ds Max 2017                        19.0.1072.0
Autodesk AutoCAD 2014 - English         19.1.18.0
Autodesk Design Review 2010               10.0.0.108
Autodesk Inventor Fusion 2012              1.0.0.79
Autodesk Navisworks Simulate 2017      14.0.1298.75
Autodesk ReCap                                     1.3.1.39
Autodesk ReCap 360                              3.0.0.52
Autodesk Revit 2016                              16.0.490.0
Autodesk Workflows 2016                     6.3.0.19
We are just checking that the above software and version number will run and be compatible with Windows 10?
Thank you for your help and if you require any further information, please do not hesitate to contact me on the number below.
Daniel Craythorne
01785 503848
dbroad
en respuesta a: Anonymous
This is a users group. Certainly none of us are qualified to make that determination and cannot do your job for you.  I can guarantee that some behavior will vary and accommodations will need to be made, even for the latest software due to service packs and updates.  I have used the 2014, 2015, 2016 and 2017 AutoCAD products with very limited loss of functionality (tempoverrides).  Design Review works fine. Windows 7 is end of life though.  Move on.
Architect, Registered NC, VA, SC, & GA.
pendean
Read this from Autodesk http://autode.sk/1IY4C2X
Contact a reseller for more details and info about your needs, this forum is not the best source http://www.autodesk.com/resellers/overview
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
Many of the application s that you have listed are not supported on Windows 10. Here is an article that lists AutoCAD compatibility.
John Vellek
en respuesta a: john.vellek
Hi @john.vellek
Thank you for your reply. I will review the link you sent and see if I can cross some of the applications off my list. I appreciate this is a long list of applications and therefore hard to give an overall answer to all of them but I am very happy with the help I have received.
I will now review other options but I just wanted to make sure I couldn't receive all the answers early on from a Autodesk Guru.
Thank you for your help and please be advised I will be acting upon any knowledge anybody can divulge regarding these Autodesk products.
