TheCADnoob
en respuesta a: Anonymous
That's as it should be. (i believe)
Are you saving from the command line or are you using the file dialog box?
There are basically three different ways to save.
QSAVE:                 Saves drawing with current filename.
SAVEAS:               Saves drawing as new name, continues in new name.
SAVE:                   Saves drawing as new name, continues in old name. (Command line only)
(from between the lines)
Try changing your save method and see if it works.
CADnoob
Etiquetas (4)
