2524 Vistas, 3 Respuestas
Automatic plot in CAD.
Hello.
Is there ways to plot that each of sheets convert to PDF as automatically ?.
For example, something drawing has a lot of product with sheet individually.
Therefore, could each of sheets plot automatically?.
Thanks.
carl.coghill
en respuesta a: Anonymous
Yes, use command BATCHPLOT
Carl Coghill
Senior Designer
AutoCAD 2018
Windows 7 Professional 64bit
LinkedIn
imadHabash
if i understand your question that you want to plot sheets (hard copy) while it's printing to PDF.. the answer is NO because AutoCAD can handle with one plotting procedure in a time.BUT you can use PUBLISH command with already page setup prepared and plot all of your sheets with one procedure command.
also you can active Auto publish from Options > Plot and Publish > Auto Publish.which by different action (Save,Close,Prompt on save and Prompt on Close) you can plot as soon as you do that action.
Imad Habash
carl.coghill
@Anonymous
Note that PUBLISH and BATCHPLOT are the same command.
Carl Coghill
Senior Designer
AutoCAD 2018
LinkedIn
