- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Annotations Popped Up Out of no where?!? Why?
This is an elevator bank that would usually just have the elevator number, when pasting this drawing onto another these annotations I have never seen before came up? I am curious as to why this happened and how to make sure it doesn't happen again?
Thanks!!
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thanks!!
Curious if these are Attributes? Have you messed with ATTMODE yet?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
I am curious if the block definitions for your tags are slightly different from drawing to drawing. Can you attach a couple drawings so I can take a look?
You might also try using BATTMAN to take a look at the attributes to see if they are visible in one drawing and not the other.
John Vellek
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem.
Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please attach a drawing if you want me to investigate this issue for you.
Please select the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
