- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
It's kinda hard to explain but I'll give it a shot.
The block is now empty. When I need to create a new version, I want to add a '4' to the block. When it's the 3rd version, I want to have 3 times a '4' in my block. I can't use the visibility parameter, since I used that one to select the person who made the drawing.
I can easily replace the attributes by normal text, since it's always a 4. But that means every page (tab) has the same version, and that's not always the case. I want to keep them as attributes to make changers per paper, but for now I want to select them all to set them all to the first revision.
It looks complicated, but the main question is quite simple: "How to select every block in my *.dwg (to fill in 1 or more attributes)?"
