scot-65
en respuesta a: Anonymous
Have you tried to open image in a editor (such as PAINT),
copy to the clipboard, then inside the destination file use
command PASTESPEC? (Edit --> Paste Special...)
If that is not the way to proceed, then do the above in a
blank DWG file and save that file and use it as a block.
Command INSERT.
This method helps when underlaying PDF's and the PDF
does not want to cooperate (scale and rotation) in the
destination file.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
