1125 Vistas, 3 Respuestas
I can't print to the HP DesignJet CM1055 plotter through AutoCAD 2017
hello, my coworker is having issues with printing to the HP DesignJet 1055CM plotter, she uses AutoDesk 2017 and the OS is Windows 10 . She used to print with Windows 7/ AutoDesk 2014. How can I fix this ?
Etiquetas (1)
en respuesta a: Anonymous
I could be wrong but I do not think HP has produced any win 10 drivers for your plotter. Best bet may be to plot to pdf and then print the pdf to the plotter  using your pdf reader? Just a thought.
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
The printer model is quite old and the lack of a driver that is designed for current Windows versions is likely at the root of the issue.  You might try the HP Universal driver and tell Windows that it has a newer (different) device such as one of the DesignJet series that has similar paper options and sizes.
John Vellek
pendean
