en respuesta a: imadHabash
hi thanks this worked and the presspull command is working, however i have another problem with another command now lol, ive mad a surface using the patch command and have attempted to use the sculpt command to convert it into a solid but it's saying there is no water tight volume yet it clearly is, i'll make another thread about it but if anyone could help me out with it here that would be great, attached file, on the right is with a surface on the very bottom and is flat, on the left the surface is raised on the z axis by about 0.01 to ensure and intersect, and the object group on the right is what the patch was made from
