imadHabash
en respuesta a: Anonymous
3D gizmos help you move, rotate, or scale a set of objects along a 3D axis or plane.and it's displayed automatically when you select an object or subobject in a view that has a 3D visual style.(see attached image)
  • Gizmos are available only in 3D views that are set to use a 3D visual style such as Hidden.
  • by change the value of the DEFAULTGIZMO system variable you can change the default gizmo display.
  • you can switch between the gizmos and when it's active and appeared over the selcted item,just select any of 3 axis (blue,red,green) then press Spacebar repeatedly to cycle through the other gizmo type.
if you do what mention above you will reach easily to what you looking for (3D rotate gizmo) three circles.(see image below)
Good Luck..  :cara_guiñando_un_ojo:
Imad Habash
