imadHabash
en respuesta a: Anonymous
your two shape just need to be FLATTEN,put them at plan top view then use FLATTEN command. then you can PressPull it as you wish.
Command: FLATTEN
Initializing...
Select objects to convert to 2d...
Select objects: Specify opposite corner: 60 found
Select objects:
Remove hidden lines? <No>:
Good Luck..
Imad Habash
